![]() | Home > General > 4.2 v 5 litre facelift 2010..... |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
Thought you got a light on the dash or message, slow to rise when compressor broken |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I had one fitted before picking mine up and it was around £600 fitted. Steve. |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
Turned a corner and metal was grinding on metal on the right front wheel. WTF?!?!
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 ![]() ![]() |
In the nicest possible way this is probably a lesson to you.
Crack a lackie 2006 RRS Supercharged 4.2 HST muthuaflecka! |
⏰⏰ 2006 RRS Supercharged 4.2 HST muthuaflecka! |
Wow not sure what you want from this forum everyone has tried to give you a little bit of advice/help but I think the best thing for you is to hand it back and find another car as I don’t think these are for you at the present time |
Sometimes a rear caliper being stuck on (on opposite corner) can sound/create this. Touch the rear wheels after a drive, and see if one is hot. Callipers are from £40 on ebay. Very common issue on RRS |
It was the front right. Maybe same problem 2006 RRS Supercharged 4.2 HST muthuaflecka! |
I had this in mine. It sounded like something was touching in the front wheel arch when Corning on roundabout but it was the opposite rear corner at fault! |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 ![]() ![]() ![]() |
I owned a First Edition 4.2 SC for 7 years and never found it to be floaty so that's not the natural state of things.
