![]() | Home > General > Potential New Owner (with a question) |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1884 ![]() ![]() |
Try looking at the brochures for the model year you are interested in:- http://www.auto-brochures.com/land_rover.html 2023 P440e SE Dynamic on order -cancelled
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5045 ![]() ![]() ![]() |
I believe HSE or Autobiography is the specification/trim level |
Are you looking at petrol or diesel.? I might have a nice SC insantorino for sale
Mark-Mills Member Since: 03 Jul 2018 Location: Hemel Hempstead Posts: 6 ![]() ![]() |
Hello Gents,
If your going for a diesel I would consider a SDV8 which only comes in Autobiography spec,,keep well away from 3.0 sdv6 with the crankshaft issue.
Oh great! A known problem to contend with. That complicates things. |
Have a good read on here before you purchase,,They are probably one of the best cars on the road when they are running ok,,the 3.0 sdv6 has known problems with the crankshaft but LR don't know which cars & it could go at any time without warnings,,as for the svd8 4.4 ive not heard of any serious issues with them & if you have 50k you will probably pick a 2015 with lowish mileage.Plus try & buy from a LR dealer as you will get 2 years LR warranty.Im on my 6th sport & only had 2 minor issues which were dealt with under warranty & I wouldn't buy without LR warranty.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9060 ![]() ![]() ![]() |
It is a known issue but, in reality, it seems to be a minor risk - LR have sold a lot of 3.0 diesels and crank failures aren't exactly a common occurrence. I'd go with the SDV8 though - the V8 diesels are good engines but relatively rare. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thanks for the advice. It sounds like I should keep an open mind on the 4.4 diesels. I had previously discounted them in my search. |
RAW Member Since: 05 Apr 2018 Location: Devon Posts: 55 ![]() |
I’m on my 5th V6 having them in Discovery’s as well and i have had no issues, just keep the service history correct and to be honest i use my dealer as then if an issue did occur they can not pass the blame, ive just taken out extended warranty on my disco and the crank is covered as the service history is up to date and all been done by dealer from new. MY18 RRS Autobiography Fuji White
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
If you can’t find one with ivory interior then cirrus could be an alternative - for example this one on the LR used vehicle search site: http://www.usedvehicles.landrover.co.uk/search#/details/2871776 |
That one looks pretty stunning but a bit out of my league pricewise.
That looks like a very nice car - you just need to take a bit more care if buying privately. Don’t forget that you get a full two years warranty if you buy used from a LR dealer - not just the balance of the original warranty (just over a year in this case). |
That's a good point. Despite a previous bad experience with JLR extended warranty I would plan to look at adding that again. I will give them a call tomorrow to get an estimate of what it is likely to cost. |
