![]() | Home > Maintenance & Modifications > Autobiography exhaust tips TDV8 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5109 ![]() ![]() ![]() |
As the Diesel tailpipes point down and A/B ones come out basically straight, I would think you will need to cut the downward bend off. Also will you not need the A/B rear bumper as well for them to look right or at least cut the original bumper where the exit the car ?
RRSV8 Member Since: 18 Mar 2018 Location: nottingham Posts: 56 ![]() ![]() |
Thanks pal, Will be fitting AB bumper as well. |
The AB style diesel tips bend down too, the open square end is fake. 2019 5.0 SC SVA (Current)
Yes, but the outlet from the A/B rear silencer is straight and as you say the bend is in the tailpipe finisher, as they never produced a pre-facelift A/B Sport they were only introduced from MY10 on, then the bend is in the rear silencer outlet pipe on the diesel pre-facelift.
I see what your saying now, cut the bend off the back box and replace with the new AB style bent tips. 👍 2019 5.0 SC SVA (Current)
Yeah, sorry should of made it clear that I was referring to rear silencer outlet not the actual finisher tip.
