![]() | Home > General > VEBA |
I’ve got Rosen after markets in mine and it defaults to headphones first, then when you press the mute button it flicks to a transmit frequency (which it shows on the screen) and you tube your radio to that frequency for the sound. Yours could be similar. 2019 5.0 SC SVA (Current)
I have rossen as well and tune the radio in to the frequency to what it says ob screen if your lucky and it has spme one may have stored the frequency as a station |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
Didn’t work but thanks 2006 RRS Supercharged 4.2 HST muthuaflecka! |
Does it work through head phones if you plug them in |
No doesn’t work off the headphones . The radio works through then though 2006 RRS Supercharged 4.2 HST muthuaflecka! |
No they don't. the radio comes through fine on the headphones but not the DVD 2006 RRS Supercharged 4.2 HST muthuaflecka! |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Hi Andy,
Are they infa red head phones or plug in |
Plug them into the door which has controls on them 2006 RRS Supercharged 4.2 HST muthuaflecka! |
So if they are the ones that come with the screens they will either be spliced in some way to the aux system which you say you have tried and they don't work or they are wireless transmitted over the vhf radio so you need to find the frequency which i think on mine is between 87-88 fm also you may need to try the different AV'S on the unit's |
Or search google with your model number and see if you can find the user manual |
Sadly the FM search was fruitless! May take it to a specialist as I’m sure it’s a v simple fix 2006 RRS Supercharged 4.2 HST muthuaflecka! |
Ring the garage you bought it from and ask for the previous owner's phone number as you would like to speak to them about the dvd setup |
