![]() | Home > Technical > Whistling suspension? |
Does the compressor continuously run? 2019 5.0 SC SVA (Current)
Get your indy to read the codes as there is a light on there will be a code |
RRS_FR Member Since: 22 Oct 2017 Location: 46700 + Dubai,UAE Posts: 25 ![]() ![]() |
How do I check re the compressor?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9133 ![]() ![]() ![]() |
Front off side is where the front air suspension valve block is located. That'd be the first place to look if you can't do a code read. Check for leaks from the valve block and from the pipes connecting to it.
Update and thank you to all who helped!
