Home > Technical > Cool box/fridge
Brit Plumber
mine turns off when the ignition is turned off, which can be a pain sometimes. I like to add in a freezer block if it will be left parked for a few hours with 2 pints of milk in it for the kids. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #560411 Sun Jul 01 2018 8:52pm
DEVON wrote:
Cheers RRSTDV8 Thumbs Up
Did they change the design so it stays on ??
I’m pretty sure the fridge I bought from the bay of fleas was from a MY10 , so maybe that’s why it doesn’t turn off with the ignition. But it does fit and works perfectly .
Devon
I understood that they changed it so that it turned off. 2012 SDV6 - it's missing a couple of cylinders
Post #560419 Mon Jul 02 2018 7:18am
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Definitely switches off with ignition in my 2012 sdv6. Been parked up 5 mins or so, ignition off, power is supplied briefly afterwards but as soon as my dashcam powered off I flipped the lid and although switch is on it is definately off, eg no fridge noise or green light.
Post #560463 Mon Jul 02 2018 5:10pm
geoffsnook
My 2005 switches off itself after a few minuets Thumbs Up
Post #560472 Mon Jul 02 2018 5:53pm
DEVON
I’m assuming from the replies , mine is fubared Whistle
Left for work this morning with my ctek connected and the switch for the fridge switched on ,
Got back this evening expecting my sport to be on fire !!! But all was fine and the fridge was still running ?? On the plus side , the drinks are really really cold Rolling with laughter Rolling with laughter Rolling with laughter
In future I’ll just have to remember to switch it off !!!
Thanks to all who replied
Devon.
Post #560483 Mon Jul 02 2018 6:39pm
Father Jack
My 2012 did so one time as well at 40 mph. 2 Turbos f Censored d themselves at once Thumbs Up
Post #560484 Mon Jul 02 2018 6:48pm
Cymruambyth
Wales
DEVON wrote:
From what I have read on here Steve , some are blue and some green ?
I can’t find anything regarding if it should switch off with the ignition Thumbs Up
Thumbs Up Steve.
Post #560547 Tue Jul 03 2018 8:43am
flydive
If I remember correctly there are 2 fridge types.
The D3(and contemporary RRS) with blue light and D4 one, green light.
The D3 one has voltage sensing and will switch off.
The D4 one does not have the voltage sensing and will not switch off in a D3 or early RRS ( I think the sensing is part of the wiring in the D4) '08 RRS TDV8
Post #560564 Tue Jul 03 2018 11:24am
Tim in Scotland
The first one fitted in my 2007 TDv8 was blue when it failed the 2nd one had a green light.......... both switched off with the ignition though. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #560573 Tue Jul 03 2018 1:39pm
Father Jack
In my 012 my sdv6 hse, fridge on light is green and it definately does not stay on with ignition off and vehicle powered down.
Post #560576 Tue Jul 03 2018 2:20pm
Bill Portland
it's the same for my 12 autobiography Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #560577 Tue Jul 03 2018 2:27pm
LJRH
I have an ‘06 with a blue light and mine turns off Rolling with laughter Noisy black one
Post #560578 Tue Jul 03 2018 2:37pm
DEVON
Thanks all Bow down
Mine is definitely from a MY10 sport with green light , seems like it doesn’t have voltage sensing but hey ho !!!
I’m happy I have it instead of a big black hole , and it works brilliantly .
The wife thinks I have a few chilled brain cells Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up
Post #560606 Tue Jul 03 2018 7:05pm
