![]() | Home > Technical > Air con problem? Strange one |
| DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264
I’m no expert , but did they pressure test the system before re-gassing it ?
| ben_edwards30 Member Since: 08 Jun 2018 Location: Shropshire Posts: 20
I thought it would be a leak but the rear vent being cooler confused me a bit? |
That is strange ??
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
Had a similar problem with my other car a small Renault it took the air-con guy a while to find it was 2 small leaks so i would say get it checked it will more than likely be low gas |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Take it back as they have probably put a dye in it, then they can use the black light to find the leak. I think the cooler vent is probably a coincidence, try a thermometer on each one. 2019 5.0 SC SVA (Current)
| All times are GMT |
