![]() | Home > Technical > Fusible link blown. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
Bit late to the party here, but the plastic cap on the end of the compressor where the air pipes come out have been known to crack between the pipes. I had this on my D3 and diagnosed it by spraying it soapy water and watching for bubbles. I bought an aluminium one off ebay for about £35 and fitted it on the driveway in about half an hour. I guess because it hadn't been overheating for too long the compressor itself wasn't goosed and I got away with it.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
you can always disconnect the thick wires to the compressor and see if the fuse no longer blows |
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
Howler... I’ve used these before for a compressor and it is the exact make and fit. I think LR use this make now
