![]() | Home > Technical > Suspension query. |
Just a thought and going back to what was said earlier, I assume the suspension must respond to an obstruction by sensing the drop to access is slowed or restricted. What if corrosion on the struts or suspension is increasing resistance, hence being slow and causing the ECU to think there’s a restriction to select off road height. Maybe all the suspension woes are interlinked, noises, slow and off road height when access selected? 2019 5.0 SC SVA (Current)
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
It didn`t try to reach off road. It actually dropped to access height as I wanted but the screen said it was in off road |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
I don't think a battery reset will fix this. Not worth trying.
I tried it earlier with windows open and as it was rising I could hear air now and then so a leak may actually be the issue. Steve. |
check for a noise under the passenger side (the tank) |
Cheers guys. I`ve text the garage I use to give it the once over. Once THIS problem is sorted it`ll be going on ebay |
DEVON Member Since: 15 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
That’s a pity cause you’ve sorted all its little quirks and problems , and now someone else will benefit .
I know mate...I did think that but I just can`t be doing with thinking, what next every time I drive it. I bought my dream car (E46 M3) and only kept it 12 months because of all the constant faults. Time to cut my losses |
Well that’s fair enough mate ......
I think I was spoilt with my Focus ST....3 and a half years and nothing broke....I don`t think I even changed pads |
RS focus won't even last a year without requiring a replacement engine or head gasket.
Yeah the mk3 does nothing for me. Now...if I had a spare 20k...mk2, yes please |
Just been to my sister's house and parked half on her drive. So I thought get bro in law to sit in the sport and lower and raise it so I can listen for air or something. Worked fine...done....up, in seconds and again!!! Wtf? Steve. |
