Home > General > 2.7 TDV6 HSE vs 3.6 TDV8 HSE spec differences
Page 3 of 3 <123
geoffsnook
Are you not the one who is looking to buy one so as long as you accept what it is and what the insurance company deem it to be then just pay the premium Whistle
Post #559847 Mon Jun 25 2018 7:49pm
Calcifur
Sounds like I have enough to worry about mechanically with out having to bother with a vehicle that doesn't match its log book. [/s]
Post #559849 Mon Jun 25 2018 7:57pm
geoffsnook
I think if i was you i would look at another marque as these can be very expensive to run if they go wrong but it is a risk you take as to how good a sport you get to start with but you will need deep pockets as even tyres are not cheap Thumbs Up
Post #559851 Mon Jun 25 2018 8:05pm
geoffsnook
There are a couple for sale on here you may have to travel as i did for mine Thumbs Up
Post #559852 Mon Jun 25 2018 8:19pm
Calcifur
No thanks. Been wanting a Land Rover for years. If i had my way I'd have had a D3 a while ago but her indoors think they are too 'Boxy' so no go. If I play my cards right might be able to convince her on an RRS. Just have to find the right one. Failing that might have to be as new a FL2 as I can find, or heaven forbid an X5. (nothing wrong with an X5, I just think they are a big clinical inside and lack passion)
2nd edit!.....
Just been looking through autotrader again and EVERYTHING that isn't a Land Rover is dull looking (I know looks aren't everything, but..) They all just look naf on the inside. Doesn't help that I love big, proper, 4x4s
However, if I do end up with an RRS and it all goes tits up, feel free to say 'I told you so!" Rolling with laughter
Post #559866 Mon Jun 25 2018 9:59pm
They do look nice inside and out.
Jaguar landrover Italians know how to do interiors.
But it can get boring climbing in every time. I'm 6ft +
And dragging 3 tons around everywhere.
But you get use to it.
Post #559869 Mon Jun 25 2018 10:08pm
Andy K wrote:
Calcifur wrote:
Quick look on google and I can see no reference to 3.6 TDV6.
Hence me saying they only changed part of the logbook following an engine change.
If you had a broken 2.7 engine, and knew someone with a cheap/written off v8 going on your door step, I guess it made sence
It wouldn't be worth doing. You'd need a new engine loom, new gearbox (the TDV8 and SC have a stronger 'box), new rear half shafts (the TDV8 uses the same stronger shafts as used on the locking rear diff vehicles). The suspension module uses a different "tune" to the others too so you might need a new module. The TDV8 also has Dynamic Response so you'd need to deal with that - remove the DR pump and fit an idler or something? Unless your 2.7 also happened to have DR which, as an SE, I'd doubt very much. You'd need a different cooling pack too - the TDV8 uses a different radiator and intercooler. You'd also need a fuel cooler and gearbox cooler (they're both different to the 2.7). You'd also need to do an alignment as the TDV8 uses different suspension settings (toe, I think, but I can't remember off the top of my head). You'd really want to fit the Brembo brakes too, to be honest. By the time you've swapped all of them over (assuming your written off TDV8 had them all in good condition, you'd be wondering why you'd started.
A replacement 2.7 engine would be cheaper and easier. 2012 SDV6 - it's missing a couple of cylinders
Post #559875 Mon Jun 25 2018 10:26pm
Calcifur
Maybe I should email the seller and ask what teh deal is. Something like..
'Hey Mister, How come your TDV8 hasn't got ACC or Brembos?'
and see what the answer is.
Post #559878 Mon Jun 25 2018 10:44pm
RRSTDV8 wrote:
It wouldn't be worth doing......
We aren't here to have a discussion as to whether it is sensible or economic to do it.
As the logbook has been changed I can only assume someone has done it! (probably not changed all the parts you would like) Until it is proven a V6 is still under the bonnet, I will assume its been done.
Post #559913 Tue Jun 26 2018 12:09pm
A question that would get a more useful response would be
That car doesn't look like a TDV8 and the logbook states its a TDv6. Has the engine been changed?
Post #559915 Tue Jun 26 2018 12:13pm
Calcifur
I know, I was taking the Censored ....
Post #559918 Tue Jun 26 2018 12:21pm
geoffsnook
Walk away there are plenty for sale elseware
Post #559924 Tue Jun 26 2018 1:20pm
Calcifur
Yeah it's been knocked off the it list. 2 favourites at the moment (supposing my better half gives the go ahead!!) are these I think.
https://www.thegreatwesternmotorcompany.co...1522741027
Little higher mileage than I would like, but looks tidy.
or this one.
https://premiermotorslondon.co.uk/vehicle/...v8-hse-e4/
Hate the chrome but that can be dealt with.
Time will tell....
Post #559935 Tue Jun 26 2018 2:45pm
Or the log book has an error on it, which is just as possible. 2012 SDV6 - it's missing a couple of cylinders
Post #559940 Tue Jun 26 2018 3:43pm
Page 3 of 3 <123
