![]() | Home > General (L494) > Ghost immobiliser prevents remote climate on app? |
| james5599 Member Since: 14 Jun 2009 Location: london Posts: 325
That is a good question.
| tally Member Since: 22 Feb 2018 Location: London Posts: 18
I guess the ghost only kicks in when the push to start button is pushed. |
now i have ghost installed, i can confirm my suspicions were right.
| SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827
Yes it is strange as i have heard all sorts of problems with this Ghost. SVR 2018 in Santorini Black. |
Mine works on my 2017 car- the remote start function that is. Haven’t tested my 2018 as the ghost isn’t installed yet. I did recall it throwing up a few faults on the dash afterwards that quickly went away after a minute or 2 though. I ll try it again tomorrow so I m not imagining it ! Any issues I’ve read about to do with the ghost are usually attributed to poor installation. Fitting to the wrong bus network etc. 2019 Svr and 2019 R35 GTR |
Just an update...
| npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716
mine (Audi S4) could be programmed to either immobilise the cars engine starting or stop the gear box from selecting drive as its a electronic gear box
| mannchris Member Since: 01 Jun 2014 Location: Solihull Posts: 46 |
I'd guess that even if it did you would have to stop the engine and start it again, unless the button presses can be input while the remote climate engine is running? |
the installer said the engine could be running, (manual in my case) and all the functions will work, defrosting the car, but you could select a gear until the code is entered
