![]() | Home > Maintenance & Modifications > Front discs and pads |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 223 ![]() ![]() ![]() |
Ok guys, little help here.
Thanks Steve, i did enter my reg in Eurocarparts, thats why i am asking as it gives 2 different types of pad, some are larger than the other type, also, there is no option to enter reg on profile, filled everything else in |
These
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
Do you have Brembos or TRW front calipers? If they are brembo's they will have 2 pins hence the squarer ones if they are TRW then the first ones.
This is the problem, i have no idea which i have, how do i tell without taking a wheel/caliper off??? Is there a way to tell or find out? |
Brembo may have brembo written on side of the caliper or you may be able to see pins. TRW will look like a W side on.
