![]() | Home > General > What a dipstick!!!!! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
I don't think you get an automatic notification it's low!!!
Why is changing the oil a palava? 2019 5.0 SC SVA (Current)
Because you can't check the oil level when putting it back in as east with out a dipstick |
djb222 Member Since: 17 Apr 2018 Location: Birmingham Posts: 52 ![]() ![]() ![]() |
I had read that it may be necessary to go through a calibration of the level sensor. ( from the land rover service manual). However that may not be the case for most changes. |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
You had better hope the oil level sensor is working as it is a "body off" job to get access to replace it. It took my dealer 3 days to replace mine! Under warranty, thank goodness.
