Home > General > Headlamp Upgrade Affecting High Beam Assist
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I upgraded the headlamps on my 2010 TDV8 some time ago with the following:
- Main Bi-Xenon lamp - OSRAM Xenarc Night Breaker Unlimited D3S
- Auxilliary high beam - Philips X-treme Ultinon LED H7
I was very happy with the improvement in light output in both low-beam and high-beam. Until yesterday I had never driven in a situation where the high-beam assist was activated.
The following problems now exist when the high-beam assist is activated.
1) activation of high-beam is no longer as responsive.
2) high-beam now shuts down when ever road signs appear.
The above two issues were never evident previously when the factory headlamp bulbs were installed.
Has anyone else exprienced similar problems.
Post #558881 Wed Jun 13 2018 2:38pm
Actualy mentions in Owners Handbook that reflective road signs can affect the operation of auto high beam, so may be relevant to high beam assist as well.
Post #558917 Thu Jun 14 2018 5:08am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
High Beam Annoyance
I am surprised you are able to keep the HBA enabled, i find on the east coast it was more
dangerous to other drivers as the High Beam quite often failed to dip when there was
oncoming traffic, so disabled it in the vehicle settings. Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #559166 Sun Jun 17 2018 6:07am
Brit Plumber
Mine is fine on a straight road but if there’s a corner, it doesn’t dip unless the oncoming vehicle flashes me, then it works instantly....but too late. I’ve also now disabled it. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #559171 Sun Jun 17 2018 7:37am
Zilch
exactly that B-P, and the roads on the East coast of Australia are not exactly straight.. Another Pommie Bar Steward down under
Post #559247 Mon Jun 18 2018 3:03am
