Home > Technical > Did all L320s have TPMS
Brit Plumber
I don’t think my MY12 Supercharged has TPMS but should it have? It has had Overfinch 22s fitted but I don’t see why they would need to remove the TPMS. Any thoughts? I’m thinking of trying to find and refit all the parts again as I’m lazy and hate having to manually check. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #559000 Fri Jun 15 2018 8:55am
Tyrefitter
Not all L320's have TPMS & if they have it (iifc) it doesn't work the same as L494 which shows each tyre pressure,,the L320 just flags up low tyre pressure but doesn't tell you which tyre.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #559002 Fri Jun 15 2018 9:08am
SRE
Spain
I think in the UK TPMS was mandatory from Jan 2012 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #559007 Fri Jun 15 2018 9:54am
Brit Plumber
So mine has probably never had it and wouldn’t help much anyway. I think I have a small leak in one tyre and I can visually see when it’s down so will just have to stick to that method. Thanks for the reply. 2019 5.0 SC SVA (Current)
Post #559008 Fri Jun 15 2018 9:56am
SRE
Spain
You can always check your vehicle build spec on :-
https://topix.landrover.jlrext.com/topix/vehicle/lookupForm In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #559012 Fri Jun 15 2018 10:09am
Brit Plumber
I’ve already looked but it doesn’t say either way. If it doesn’t have something it says less xxxxxx (I.e. I don’t have a sunroof and it says “Less opening Roof panels”). So I can only assume it was not an option or fit. 2019 5.0 SC SVA (Current)
Post #559016 Fri Jun 15 2018 10:20am
Bill Portland
My December 2012 Autobiography doesn't have it, which I always thought was odd. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #559019 Fri Jun 15 2018 10:55am
Brit Plumber
It is odd considering the AB is supposed to be the top of the line. 2019 5.0 SC SVA (Current)
Post #559021 Fri Jun 15 2018 11:22am
Mandatory from 1st November 2014, factory option on RRS1 have it on mine but pretty usless system really, only flashes warning if pressure drops below around 25psi., but does tell you which wheel, thats it.
col
Post #559023 Fri Jun 15 2018 11:30am
I thought most supercharged ones had it. Obv. not.
Post #559024 Fri Jun 15 2018 11:49am
