![]() | Home > Technical > Battery problems or not ? |
That warning is usually for the auto stop/start battery not the main car engine battery - take the car for a 15-20 mile run to recharge the stop/start system battery and then try operating the auto stop/start system and it should work fine whereas if you tried to use it with the warning showing it wouldn’t auto stop/start. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 934
I did just that this afternoon, about a 30mile fast run & noticed the stop/start did not happen when I returned home which made me think there was a battery problem. I did not realise there were 2 batteries. Do you know where the stop/start one is situated, then I could check the voltage. Thanks for that. |
I don’t know where it is but Disco_Mikey will! If your aircon was running a lot it is possible that it was putting too much load on the systems for stop/start to work - i’ve Noticed that in my car the stop/stat will restart the engine within a few seconds of stopping if the aircon is blasting out cold air in traffic, also if it was really hot (I cannot remembervthe uppervtemperature limit) outside then it won’t work anyway like in cold weather stop start won’t work below a set temperature because thenload is too high for the reserve battery. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
The stop start battery is located behind a trim panel on the right hand side in the luggage compartment. I had a dash cam fitted & the numpty used it as the main power supply |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5153
Not sure if this may be of some use as well.
Thanks everyone, will try to have a look at it later today |
Peachy
It's the full piece about 18in long - 15in high |
Pic would be good if its not too much trouble |
Thanks for that, I was just pulling the recessed piece |
Finally got round to checking the secondary battery after a struggle pulling down the trim. The car had been sitting for about 6 days. When started it came up with low battery, start car, so after opening up the trim, I checked the voltage which read
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
Is that 13.02V with the engine running? If so, might that suggest the alternator isn't pulling its weight? 2012 SDV6 - it's missing a couple of cylinders
No that's with the engine off. I have just disconnected Ctek as it says fully charged, jumped in, nothing on & it says low battery, start engine |
