![]() | Home > In Car Electronics > Sat Nav screen compatibility between 2005-2009? |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143
what year is yours?
| Lethallegend72 Member Since: 25 Feb 2018 Location: Oxford Posts: 11
Mine is a 2006 SUpercharged. It has rear screen entertainemnt fitted (not sure ir that matters)
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
It should be fine to use a screen from the same model you can change the glass |
The front piece of glass/screen is not damaged, it’s the layer behind. I asume this is also serviceable..
Not sure you will find one on ebay but if you do could you post a link |
Found a 2010 screen for mine on aliexpress so would think they will have them for yours |
I found a russian website to get the correct part number of the Nav screen for my car from here using my VIN number:-
One is for the tv and the other is for the camera i think i have ordered the replacement screen from aliexpress for the £32 delivered |
| All times are GMT |
