![]() | Home > Faults & Fixes > 2005 Range Rover sport 4.2 v8 supercharged missfire issue |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
If it ran out of fuel it may be a fuel pump but it sounds like the cat may have collapsed and blocked the silencers. 2019 5.0 SC SVA (Current)
| Shauny0809 Member Since: 01 Jun 2018 Location: Wigan Posts: 33
Would that cause missfire the drivers side cat is defiantly broke and I can hear big piece rattling and it can’t get past the bend on the exhaust |
The emissions controls will be trying to adjust the mixture to get the emissions right which is probably why you have the misfire. Sounds like you will need two new cats as given the age of the car the other side might be worn out if unburned fuel has gone down it. It might cost more than the car is worth to rectify the problem as replacement cats are not cheap. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Yea the cats are exspensive but was thinking of getting the cats gutted out for now to see if it improves maybe see if like a gd mapper can alter the difference with out them in or something |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5144
yeah I was thinking that.
Yea think that be best bet every car I’ve owned have had no cats due to being decated etc on my Subaru’s so any see why it much a difference for this as still petrol end of day |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
C an you get some decat pipes made for it and see if that works |
Happy happy the passenger side cat was blocked and broke she’s running perfect now thanks |
gutted both cats ? |
Yea I gutted the drivers side as that was the 1 wat was making a noise still was same after gutted it so I changed pump and filter today and that didn’t work so got |
lucky you.
| All times are GMT |
