![]() | Home > Maintenance & Modifications > Wing Mirror Indicators and DRLs |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
I have a 07MY RRS TDV6
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
Not thinking of these by any chance are you ?.
Hi Col - I think that is it - thanks for that.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5094 ![]() ![]() ![]() |
DRL's that go in the fog lights are usually a ring, so its obvious its a DRL not fog. |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Thanks for the link - So you basically built a kit from scratch - I take it that you did not find a kit to do what you built?
Thanks - great information. I am not after anything other than simple DRLs - when engine is running with lights off the DRLs are on and when headlights are on then the DRLS are off.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 408 ![]() ![]() ![]() |
Be aware that if you use a DRL controller that uses a voltage sensing relay to switch on the DRL lamps then when you plug a battery charger in the DRL lamps will light up when the voltage at the battery terminals exceeds just over 13 volts. |
