Home > General > New key case
Sham91
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Bonatti Grey
New key case
I’ve seen genuine key case for my RRS TDV6 on duckworth parts.
Is it easy to swap cases?
Also what battery do the keys take?
Post #558351 Wed Jun 06 2018 10:30pm
Brit Plumber
I bought 2 cases, had to use the guts from my damaged keys in the new key cases. Pretty easy, about 5 mins per key. Just strip the old one out as if you were doing a battery swap. Then I used a soldering iron to melt the plastic tabs off the posts that hold the circuit board in to the case. Swap the guts over and use the soldering iron to melt the posts and form the new heads to retain the circuit board. Reassemble and test on the car. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #558358 Thu Jun 07 2018 6:34am
There are two different cases for the facelift RRS1 Vin. No's AA212145 up to BA717905 (LR052905) and CA000001 up to DA806522. (LR078921 Matt) & (LR059383 Shiny) I don't know if the earlier internals will fit directly into the later smaller case though, although if you look through the wanted section I believe there is someone who is offering this mod to upgrade to later key fob. There are actualy two different cases for the later fob although totally interchangeable one is just a matt black rough finish the other is a smooth black finish almost like piano black. I changed mine a couple of years ago and used the matt black one's, as the lacquer on the original shiny one's was actualy flacking off and looked very tatty.
Post #558364 Thu Jun 07 2018 7:22am
Sham91
Thanks for the response guys I have just dropped him a PM Smile
Post #558375 Thu Jun 07 2018 9:36am
