Home > General > Steering vibration still |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 |
Wheel bearing track rod drop down link ball joint
Thu May 31 2018 9:51pm |
dieselwoofer Member Since: 21 May 2018 Location: down south Posts: 23 |
It’s strange that nobody can find it. I was told all the suspension bushes were replaced a year before I brought it
Thu May 31 2018 9:53pm |
Exceluk Member Since: 01 Mar 2013 Location: Nottingham Posts: 10 |
Thu May 31 2018 10:33pm |
It’s defiantly a weird one.
Thu May 31 2018 10:57pm |
Just remembered, I have a 57 TDV8, owned it for 6 years now but when i first had it had this strange vibration under acceleration when the steering wheel was turned slightly to the left, took it back to the dealers (under warranty) two days later they said it was a heat shield touching the column.... i still doubt that to this day but they did cure it whatever it was.
Thu May 31 2018 11:56pm |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
i suspect its your cheap davanti tyres that are the fault...get a 'road force' wheel balance and you'll see the difference or try a different set of wheels/tyres. |
Fri Jun 01 2018 8:16am |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 387 |
another potential issue is binding brake caliper.... |
Fri Jun 01 2018 9:28am |
[quote="scarey"]i suspect its your cheap davanti tyres that are the fault...get a 'road force' wheel balance and you'll see the difference or try a different set of wheels/tyres.[/quote]
Fri Jun 01 2018 7:09pm |
[quote="PC76"]another potential issue is binding brake caliper....[/quote]new front calipers :thumbsup: 2011 RRS facelift |
Fri Jun 01 2018 7:10pm |
