Home > My Range Rover Sport > 5 weeks after purchase.....
djb222
After having had a Freelander 1.8K series, from new, for the last 14 years as my daily I thought a change was overdue.
5 weeks ago I purchased a 2010 RRS HSE 3.0TDV6 in Santorini Black. And what do I think of it? Hmmmmmm well after the first week it went back as only normal height was selectable...Fixed. Then a few days later I noticed it was sitting at a different height at each corner, back it went...after the compressor was fitted they didn't recalibrate the suspension,,,now fixed.
I am now hooked it drives great and is so comfortable and easy to drive, don't know why I didn't buy one sooner.
I'm even getting better economy than my Freelander, currently at 25mpg mainly short distance town driving.
Just one niggle on hard acceleration some smoke from the exhausts ( read the threads and checking it out)
I think its Santorini Black but no paint code sticker in the usual, passenger door..... is there any other way of telling?
Post #557765 Wed May 30 2018 5:18pm
SRE
Spain
Looks nice, you now need black side vents and grill.
Example of Black vents and Grill on my 2011
 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #557768 Wed May 30 2018 5:42pm
SRE
Spain
Smoke from the exhaust could be when the second turbo kicks in, this is a know problem.
https://www.disco3.co.uk/gallery/albums/us...0-%203.pdf In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #557774 Wed May 30 2018 6:01pm
SRE
Spain
Better still
http://www.disco4.com/forum/d4-secondary-t...urbo+drain In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #557775 Wed May 30 2018 6:02pm
djb222
Many thanks for the info..
Post #557788 Wed May 30 2018 8:54pm
Brit Plumber
The paint code on my 2012 is on a sticker under the bonnet on the black valence across the front of the car. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #557793 Wed May 30 2018 9:11pm
djb222
Thanks, will check in the morning.
Post #557794 Wed May 30 2018 9:13pm
d-9
Facelifted L320s look good
Post #557798 Wed May 30 2018 10:55pm
