| RRSPORT.CO.UK | ||
|  | Home > Technical > Hopefully a coincidence |
| IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 874    | A lot of detail missing. For one what model ? For two the wheel size does not make sense. I have been told on my model that the wheel diameter has to be set? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. | ||
|  Sun May 20 2018 10:26pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Hi & welcome to the forum,,as for changing the wheels that won’t make any diffence if it’s a L494 then they fit the 21’s as standard,the oil level,did you leave the car 15 minutes before checking as the oil needs to settle before it will give a reading & by putting more in you could have overfilled it now as it might have been to the full level.
|  Mon May 21 2018 3:08am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Hi and welcome, pure coincidence it happened after changing wheels, have been running 275/45 x 21" SVR Wheel & Tyres on a facelift RRS1 for well over 3 years and have never had any problems or faults whatsoever plus the speedo now is more accurate than it ever was without changing the size in the CCF files.
|  Mon May 21 2018 3:47am |
| Firmantor Member Since: 20 May 2018 Location: NN109EJ Posts: 8      | Thanks for the replies all.
|  Mon May 21 2018 4:38am |
| Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480      | When you say your oil level reading wasn't working how soon after stopping did you try it ? It needs time to settle. I think the advice for an accurate check is run the car to normal operational temperature, then once stopped leave for at least ten mins minimum before checking. Otherwiae a "not available" message is likely. I wish there was a manual stick but there you are. | ||
|  Mon May 21 2018 7:09am |
| Firmantor Member Since: 20 May 2018 Location: NN109EJ Posts: 8      | So the same thing happened yesterday afternoon, had driven around 20 miles at 60-70mph and out of nowhere the red triangle came up and restricted performance mode kicked in.
|  Wed May 23 2018 8:19pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | I have also had the oil level failure thing several times in the last two years and suspect that it is something to do with a software update that was carried out at the 2nd service- I get the red warning triangle in the dash with the message “ communication with oil level sensor lost” it doesn’t go into limp home mode though, when safe I pull over, switch off for 10 minutes and restart and can then cover thousands of miles before it comes back again. I also get a total black out of the TFT screen infrequently. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Wed May 23 2018 8:33pm |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594      | You'll need to have the codes read before you can get a definitive answer.
|  Thu May 24 2018 9:21am |
| Posting Rules
