![]() | Home > Technical > Lumpy strtup and Smoking issue |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
The valves can temporarily be blanked off to isolate them
RRSCruiser Member Since: 02 Apr 2010 Location: West Sussex Posts: 41 ![]() ![]() |
I saw that procedure in the LRO mag a few editions back and it seemed nearly the same amount of work to get in to blank off as it is to get and change, so I thought if I could compare the EGR valve live value trace from someone elses car that is working first, it gives me a better idea that there is a fault. Save a double bubble on labour costs
That one would run relatively well once warm, albeit a bit laggy at the bottom end
LOL, I wish we were not at the southern end of the country, need some of that experience
Live values were 100%, as in the actual positions were a perfect match for the commanded positions |
Thanks Mike, I'm taking my spiky trace is not a good sign.
Hi Mike
bump, would be good to know if this is a reasonable way (see previous post in thread) to approach this or am I creating an issue |
