![]() | Home > Faults & Fixes > 2007 RR sport loss of tv help |
Tizzard Member Since: 30 Nov 2015 Location: Nottingham Posts: 64 ![]() ![]() |
Any1?? I’ve even tried searching to see where the fuses are for the tuner box and tv system and can not find anything😬😬 |
Bit of an update been this is what it brings up if I do a system check on the front screen
Yours is a 2007 - the receiver/tuner may be an analogue one and since about 2010 we have only had digital signals for TV....... you may need a more modern digital tuner. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
It always worked fine since I brought the car as was last used a few weeks ago so can not seeing it being down to analog |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5081 ![]() ![]() ![]() |
Try Fuse 58 10amp but I think if that was blown other things may not work either.
Hi Col. I checked the fuse yesterday and was fine as it’s also the fuse for the main display up front. I didn’t no if there was a single fuse any where just for the tv tuner or something. As I don’t think it’s powerd up as it’s not showing the TV option on the main display |
Fault Code shown on the HLDF screen picture, might be worth checking co-ax cable has not become dislodged on either the tv tuner in the boot or the back of the nav screen. Only a cheap suggestion as not a audio/video engineer.
Are the connections to the antenna still all made at the rear side windows and the antennae on the glass still undamaged?
Everything seems as it should be. I’ve had the panel off and all the connections into the tuner seem fine. Orless the tuner is dead hence why I’m not getting the function on the main display up front for the tv option. Not sure it could be anything else as the DVD player works fine on the front and rear screens and the sat nav works fine🤔🤔 |
