![]() | Home > Faults & Fixes > Suspension possible leak |
Check for a leak with soapy water when its switched off the airbag may have a slight leak |
Philhudd Member Since: 15 May 2018 Location: Bristol Posts: 7 ![]() ![]() ![]() |
Thanks will do, it takes days to lower that’s the strange thing
It tells you there is a problem on that wheel with the height you may have a leak or the height sensor may be faulty but If its If it’s taking its time a air leak is quite likely and if that slow may also be a pain to find |
Great thanks for the response, I think I’ll leave it till it gets worse then
Depends if it’s an air bag then new if it’s a seal then you know how long is a piece of string |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
If there is a leak you want to fix it sooner rather than later. Unless of course you want to replace your compressor too |
