Home > Technical > How do you rate your air con?
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Hi guys,
As it's been hot last couple of days, my climate control has been working overtime.
I can feel it's blowing cold but not exactly freezing cold.
It's set at 20 and the blower is running a few rate of nots but it's not having a massive effect.
Car is a 2014 RRS AB.
Is this normal or worth a recharge?
Post #556531 Tue May 15 2018 6:38pm
Tim in Scotland
Mine is a 2015 and I run the a.c. all the time and it has no problem cooling down the interior on a hot (SCOTTISH) day, you might need a gas recharge - where I live we have had some lovely days lately and up to 22 showing on the external temperature and it’s been quick to cool the inside, even set at 19 it is fine, any lower and it is too cold 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #556533 Tue May 15 2018 6:45pm
the_big_1
Hi guess
Guess a re-gas then. It's blowing cold so I don't think any leaks? From what I read cars loose around 10 -15% gas a years so four years old looking at a loss of 40 - 60% could explain lack of performance
Post #556534 Tue May 15 2018 7:03pm
geoffsnook
Better than the air-con in my renault Rolling with laughter
Post #556536 Tue May 15 2018 7:04pm
turn it down to 19 or 19.5°
make sure the passenger side isn't significantly different.
turn the fan speed down a bit once you have been driving a while.
The automatic system is good on the old models
Post #556553 Tue May 15 2018 8:10pm
Cymruambyth
Wales
20? Well it won`t feel cold set to 20.....I`ve always turned my temp (on all cars) to coolest setting, usually 16 and then the AC is lovely and cold. Steve.
Post #556564 Tue May 15 2018 8:51pm
I usually set mine to 20 for normal weather. If it's warm then 16 or LO until it's cooled down a bit then back to 20. Means the fan's not running noisily all the time. 2012 SDV6 - it's missing a couple of cylinders
Post #556574 Tue May 15 2018 9:45pm
only yeah I have used them tricks previously. Thumbs Up
17°C and slow fan
Post #556613 Wed May 16 2018 11:04am
HughN
Wales
I set to 20°, a/c on and 'auto' all year. When it needs cool air, it blows cold air and it is chilly.
My wife, on the other hand is like Rick Wakeman on the controls in her Disco 4 - temperature up, then temperature down and fan off, fan up and then shut or open a few vents, turn temp down to 16°, wait five minutes and back to 26°. It's the same with the central heating in the house... Confused
The mobile aircon company local to me is called "Stiff Nips"
Post #556656 Wed May 16 2018 6:13pm
