![]() | Home > Maintenance & Modifications > Lowering links |
RRS Iwan Member Since: 01 Mar 2018 Location: Gwynedd Posts: 12 ![]() ![]() ![]() |
Good evening All
Just buy an IID tool and lower it as you please and then you can also put it back when you want |
Yes I have seen this mention on the forum quite a bit and it can perform many other functions from what i can see, but for 430 notes.....................mmmmmmmmmmmm |
Well you do get what you pay for |
Will I be able to program a spare key with the IID tool? If so where can I get a cheap reliable key.
Yes you can reprogram keys with the IID and it is also awful when the car sits on the bump stops and you are driving it |
And here is a key that is a lot cheaper than what land rover supply you would need to program it and reprogram your other key at the same time but make sure if you do it.It is from a reputable seller
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
yeah spend £400.
Here you go |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 320 ![]() ![]() ![]() |
The first time it pulls up a bunch of warning lights and errors, you'll be glad to have a iid tool. In a lot of cases you can reset it and carry on, mine has saved me from recovery on one occasion.
I remember stuffing my rad and cooking the head once off tossing so it can be very expensive lol |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Geoff, maybe you should keep your private life, private.
Gosh! |
