Home > Technical > Gearbox failure warning on dash
Simon58
England 2008 Range Rover Sport TDV6 HSE Galway Green
Haven't posted on here for a while as I sold my RR Sport, last October, but i brought a new shape (64 plate) in November today when the wife was driving it a message came up on the dash saying gearbox fault car shut down, would not restart - she called the RAC they came out looked at it, the guy managed to start it and shut it off imeaditely saying I can do anything with that, she is now waiting for the recovery truck to pick her up, we have done around 4000 miles in the car since we brought it, ts little over 30k on the clock now - and I think the 6 months warranty has just run out - anyone had anything similar! Forgot to mention since we have owned it its been back in to have an engine oil sensor which they had the car in for over a week at landcover main dealer. About to get into a sport
Post #556292 Sat May 12 2018 7:57pm
Simon58
Update, so when the wife finally got back last night, she told me that when the RAC man turned up, when he tried to start it there was no power, he then set up a battery charger and jump pack from his fan - she said when the incident first happened the noise was horrible - I wonder why it would have no power! could it be the starter jammed in and thats what the noise is, the car is still at the recovery firms depot as it had completely shut done they struggled to get it on the truck! About to get into a sport
Post #556309 Sun May 13 2018 8:15am
Brit Plumber
Doesn’t sound like a stuck starter, esp if it was driving ok before hand, I wouldn’t think that would kill power. I’m assuming you mean a complete loss of electrical power, i.e. no lights, horn, dash, radio etc.
If you had a gearbox warning message I would take it as read, there is a problem with the box. Did she get the message on engine start, on moving to drive, or when actually moving? If moving under power, the noise will simply be the parts in the box not interacting correctly between the engine side and the driven side. I think you need a gearbox specialist!! 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #556312 Sun May 13 2018 8:39am
Simon58
thanks for the reply she had just driven out of a car park when it happened About to get into a sport
Post #556313 Sun May 13 2018 8:47am
Simon58
She was driving at the time, when the RAC guy turned up he tried to start it, the battery had no power in it, why would it be flat if a gearbox fault - the car is four months out of manufacturers warranty too its a January 2015 Range Rover Sport with a little over 30k on the clock - full history etc etc I just can't believe it - I am sure Land Rover will just say its out of warranty!!! About to get into a sport
Post #556371 Mon May 14 2018 8:13am
Brit Plumber
I know zero about the Land Rover gearbox but if the battery is dead, it may be worth having it tested. I take it you have no lights, horn etc either. 2019 5.0 SC SVA (Current)
Post #556379 Mon May 14 2018 9:14am
Simon58
Hi yes it had no power to anything at all - car is on its way now to local dealer as I type this! About to get into a sport
Post #556380 Mon May 14 2018 9:21am
Tim in Scotland
The gearbox is like all modern things and has an ECU, these are very sensitive to even a tiny voltage drop and a low battery or a faulty alternator can throw up all sorts of strange warnings on the dash. It could be that if you battery is the original then it has come to the end of it’s life! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #556384 Mon May 14 2018 9:42am
Simon58
Car should be arriving any time now at the LR Dealer so should know in a few hours whats up with it hopefully! About to get into a sport
Post #556390 Mon May 14 2018 10:52am
Brit Plumber
Well best of luck, I hope it’s as easy as a new battery. That would save a lot of pain in the ass and in the pocket. 2019 5.0 SC SVA (Current)
Post #556397 Mon May 14 2018 12:34pm
wilf
I have my fingers crossed that you don't have a snapped crankshaft................ MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #556404 Mon May 14 2018 1:18pm
Simon58
Is that common then? About to get into a sport
Post #556422 Mon May 14 2018 3:35pm
Simon58
I am very impressed so far with Jaguar Land Rover Customer Care - they have replied to the email I sent them earlier today.
Simon About to get into a sport
Post #556425 Mon May 14 2018 3:39pm
wilf
Any news? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #556691 Thu May 17 2018 5:55am
Disco_Mikey
This was my initial concern...
Post #556694 Thu May 17 2018 7:21am
