![]() | Home > Technical > AC condenser replacement |
Don’t quote me but aren’t you supposed to be licensed to work on AC because of the environmental risks? Or is it just the filling/vacuuming side of it? 2019 5.0 SC SVA (Current)
You can work on them but you are supposed to get the gas recovered by a specialist but as its already escaped you can do it and it involves a bit of dismantling of the front end ie bumper headlights crash bar and top part of slam panel book sys 4-6 hours but if the bumper bolts are |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
Do all the rads have to come out or can the condenser be taken out on its own.? |
If you can separate them then all the better im sure it says you can but i found it easier to take the 3 out as it was tight |
I should have 2 quotes from land rover specialists near me in the next day or so. The car wont be needed all next week so i could fanny around with it myself.
Will not be cheap |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5065 ![]() ![]() ![]() |
I would like to think the front chargecooler rad is seperate.
They are all separate and you can undo them it’s quite tight in there with the 3 of them I also used an aftermarket one which was just over £140 inclusive of vat |
Chuff me.. The first quote is £770. I think thats a bit rich.. Lets se what the second is. |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
700 stings |
I would have thought £300-400 would be about right.
its really a case of how seized the slam panel bolts are around the headlights
Apart from the fact there are 3 rads on the supercharged which does make it harder than the disco 3 as i can testify as i have done both of them now |
Ive started...
