![]() | Home > Technical > RRS 2008 strange behaviour with air suspension |
sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91 ![]() ![]() ![]() |
Hi sorry to bump, but can anyone advise ?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5111 ![]() ![]() ![]() |
give the wiring to that sensor a good inspection then replace sensor |
Thanks for that !
don't know
So aside from a visual, can I do any electrical testing on the wiring ? |
With it so intermittent it's not easy. |
So it’s just failed with yellow light again.
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 ![]() ![]() ![]() |
I'm having similar problems. 4x4 info showed o/s/f sensor at lowest point. changed sensor and while I was in there I changed the wiring as at some point somebody has snapped the locking lugs off the plug. Still getting amber suspension light and 4x4 info showing that wheel low. Live data on the diagnostics shows voltage going to the sensor but nothing coming back. I got another sensor from my independent as thought it was a faulty one they had given me; NOPE, fault still there. Therefore I suspect a wiring fault between where I soldered in the new wiring and the ride height control module. I am stuck offshore so can't sort it, but not looking forward to trying to trace it |
I wonder if earthing that wire at that point you soldered it would help diagnose the issue? 2019 5.0 SC SVA (Current)
Tony666 Member Since: 27 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
Hi, I know this is an old thread but I have exactly the same fault codes, did you get a fix in the end? Replaced sensor? |
