Home > Technical > 2012 intemittant vibration ( like a flat tyre )
rodspink
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Hey all.
Wonder if any one can shed light on this one. 2012 RRS SDV6 40k miles.
Ocasionally I am getting a vibration through the suspension. It sounds like driving with a flat tyre at speed or over ruts very close together. It will Last about 20 secs then stop. Happens every couple of days. The passnger can feel and hear it. Car still feels solid on the road no pulling no massive braking issues. Its the noise you notice more than anything.
Have had new tyres, wheels balanced, new brake pads and discs.
Also under breaking i get some movement on the steering wheel like the discs are slightly warped. Car has been like this since I bought it. Have changed the discs and no change.
Strange thing is sometimes this feels worse on one day then next day hardly noticable so wondering if the issues are related.
Wonder if anyone can assist in what to start looking at or change. The intermittent occurence is a pain when trying to fault find. Its a guessing game at the mo.
Thanks
Rod
Post #555967 Mon May 07 2018 10:16pm
RAW
Had a similar fault on my D4 and it turned out to be 2 combined faults.
1st one was one of the brake calipers was not releasing which was causing a vibration until it eventually released.
2nd one was the brake pedal switch needed adjusting as there was not enough travel on the pedal so the brakes were binding.
It took a while to locate as like yours it seemed to clear but on a long journey it came back and stayed for a longer period. MY18 RRS Autobiography Fuji White
MY15 D4 Commercial Indus Silver
Post #555969 Mon May 07 2018 10:33pm
rodspink
Hey there.
Thanks for the reply. I will check them both out. I was wondering about the calipers but never seem to have excess heat at the wheel. However this could be throwing me as its so intemitent maybe they wouldnt.
I have not considered the brake pedal switch so will defo have a look.
Thanks again for taking the time to reply.
Rod
Post #556045 Tue May 08 2018 9:52pm
RAW
I used a infra red temperature gun when it starts to vibrate pull over and take the temperature of each wheel one was twice the temperature of the others thats what made them strip it all down and found one piston on the caliper was sticking and not releasing fully, Main dealers had it 4 times and couldnt find anything until i did this and filmed the vibration as you could see it on the steering wheel MY18 RRS Autobiography Fuji White
Post #556046 Tue May 08 2018 10:01pm
rodspink
Thats a really good idea.
The noise started again today. There was nothing behind me so stepped on the brakes. Noise stopped so I think you could be bang on. Going to order a set if calipers. Can do no harm.
Thanks again.
Rod
Post #556149 Thu May 10 2018 5:20pm
rodspink
Oh while I remember.
I was going to ask how many miles the D4 had covered when you were having issues.
Thanks
Rod
Post #556150 Thu May 10 2018 5:21pm
RAW
40 to 45,000 miles at a guess MY18 RRS Autobiography Fuji White
Post #556151 Thu May 10 2018 5:41pm
rodspink
Cool.
Exactly the same as mine at the moment.
Cheers again
Rod
Post #556169 Thu May 10 2018 7:49pm
