![]() | Home > Maintenance & Modifications > 2012 RRS Autobiography - Rear Video Feed ? |
I asked the same question last week but know one knew an answer. The only difference I have is that I already have the rear aftermarket screens in the head rests. I've found this which may work
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
The RSE module is located under the trim on the O/S off the boot space next to the audio amp, which in turn is linked to the TV unit under the drivers set. Most likely If there is any rear screen wiring already in place I think you will find it in one of these two places, most likely the boot, but as there are so many bits to the RSE system I'm inclined to think it may only be there if RSE was spec'd from new. I have the factory system fitted and wires seem to go everywhere.
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Thanks , much apreciated . Will keep the rears seperate . |
can you bypass VIM on 2012 sport ? i have dual view screen. |
I can’t say for sure but I assume so. It must be a speed signal or a sensor on the gear stick. 2019 5.0 SC SVA (Current)
