![]() | Home > Technical > Poor dipped headlights |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
are they cheaper than 2nd hand lights on ebay ? |
pre7amble Member Since: 01 May 2018 Location: Norfolk Posts: 13 ![]() ![]() ![]() |
Hi Andy, probably not 140 euros a pair but they are supposed to be better and Ebay is always a risk.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
How are they poor? Light output? Beam pattern? Beam projection down the road?
Light output seems to be the problem, light direction looks OK. I find that I need to use the fog lights to allow reasonable speed in the dark otherwise when you change from main to dip you feel you need to reduce speed. I do a lot of country lane driving at about 50mph so its not as though I'm travelling too fast in the dark. This was the first thing I noticed when I first used the car so I "googled" the problem and various discussion forums suggested the projectors. Visually looking at the lights they look very "grey" not sure if that is right?
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Do your headlights have that slightly blurred look? Mine are and it can't help.
I'd try a set of decent bulbs first. Could just be that they're getting past their best. I found moving to Osram Xenarc Nightbreakers made a difference to the dipped performance. Also be worth checking the height of the beam as a small adjustment can make a huge difference to the length of the beam on the road. 2012 SDV6 - it's missing a couple of cylinders
Thanks for that I will look at the bulbs, not had zenons before so at present bit outside my pay grade.
The RRS (prefacelift) had excellent headlights so I'd be surprised if it's the projector units. Not sure I've heard of anyone on here having that as an issue.
As an update, finally replaced the lamps and also scoured and polished the headlight plastic covers. Overall not a huge difference but it is brighter. I have however come to the conclusion that the real problem is that the change from main to dip is so large that I feel the dips are poor when in fact they are reasonably good.
