![]() | Home > Technical > White exhaust vapour when starting up, slow coolant drain |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
1 litre every 3 weeks is a lot.
| tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240
Thanks for the reply Andy - do you know of anything I could try/look for that would help narrow it down at all? |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
There’s not many places coolent can go, in the oil (cream on the cap) in the cylinder (possible excess vapour/water in the exhaust or on the floor. Sounds like it is going into one or more cylinders. Which one is the question. 2019 5.0 SC SVA (Current)
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
If it was the head gasket i would have thought it would have done it consistently as a crack does not come and go that i am aware of |
The coolant leak seems pretty consistent. When it's not used much it drains slower obviously, but it's still draining a little each time I use it.
If it was the head then if you stop using it then it should practically stop have you had the sustemmpressiee tested or had it sniff tested to see what’s in the coolant ie any hydro carbons |
They pressure tested it and said it was fine, and that there were no leaks in the coolant pipe (hence nothing on the drive). I didn't know about the possibility of it being EGR at the time so didn't ask about that bit |
Have they done a sniff test |
Sorry forgot to add that I don't know if they did a sniff test. Maybe I should see if a garage can do one for me. The ballpark figure I got for the gasket job was eye watering so I'd like to shop around anyway, so maybe that's an opportunity to get a second opinion. |
I would if they have not done a basic sniff test |
Normally I would say bypass the EGR coolant pipes and use it for 2 weeks and see if it still drops.
| LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227
I’ve been away a while flirting with other motors but now back with a 2013 Black edition - love it.
Ah interesting. I double checked under the oil cap for sludge tonight and there wasn't any, also no loss of power. Was the EGR cooler a big job? |
| Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245
This sounds like a classic head gasket fault, but in these modern times, a water cooled EGR might be the source of the problem. If you have increased steam from one bank of cylinders, then the water is going there, not into the sump.
| All times are GMT |
