Home > Faults & Fixes > Problem with Air Suspension... and little more....
ConnyI
Sweden 2008 Range Rover Sport TDV8 SE Orkney Grey
Hello all...
I´m new at this forum... but i´m pleased to be a part now Smile
To the problem... Big Cry
The car is Range Rover Sport TDV8 2008
My Air suspension will give me headache and sometimes error messages...
I got error message same as picture sometime in yellow and some time in red...
When it´s YELLOW, will I get error message that tell me "System Fault, Only Normal Height"
(When I have make it high them low, then normal again will it disappear)
When it´s RED, will I get error message that tell me "Aufhängungsfehl An Sich Ort Halt Motor Abstellen=Suspension failure on yourself site maintenance engine shutdown (See Picture)"
(System will raise it self to max height and if you lower it, will it raise again to max, then if you lower, then make normal, then High then lower then normal and turn on and off will the warning disappear and you can drive normal... to next time you parking)
BTW... the RED error did start after I changed to summer tires
No error message when try to read fault codes...
Anyone have any idea?
I tried to search the forum but i´m not anything like this...
Thank you all in advance...
//Conny - Sweden
Post #554571 Thu Apr 19 2018 10:01am
Cymruambyth
Wales
I can`t help with your problem but welcome to the forum Thumbs Up Steve.
Post #554596 Thu Apr 19 2018 4:35pm
Sounds like the system thinks it is grounding on an obstruction - this is why it raises the height. If you have recently changed the wheels, check that there is no damage to the height sensors or their connecting rods. 2012 SDV6 - it's missing a couple of cylinders
Post #554620 Thu Apr 19 2018 10:15pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Also
check your wheels are the same height with tyres on. there was a topic on here were someone had a different make of tyres on the front to the back and they ended up being different heights. they had to take the wheels off to put them side by side to see the height difference
Post #554635 Fri Apr 20 2018 7:25am
ConnyI
Re: Problem with Air Suspension... and little more....
Thanks Smile
ConnyI wrote:
Hello all...
//Conny - Sweden
Post #554810 Mon Apr 23 2018 9:36am
ConnyI
Hi
I have changed one tyre...
But I will try to look on the hight sensor... but I did find a leekage on fluid to the air suspenssion, it´s only little but I will change all the pipe´s
Tring to find a goo schema or workshop manual...
//Conny
Post #554811 Mon Apr 23 2018 10:14am
ConnyI
Ohh yes, it´s started after i put on the spare tyre...
Will check...
//Conny
Post #554812 Mon Apr 23 2018 10:30am
