Home > General > Weird clicking/metal noise
Montanafish
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Alaska White
Hiya guys I’ve a 2010 rrsport, I have a issue.
When I turn complete full lock to the left ( only left ) I get a horrible clicking noise till I start to straighten the wheel again. It’s only when I turn full lock to the left. I’ve had the anti roll bars done and it hasn’t fixed it. Any ideas ?? Many thanks
Post #554339 Mon Apr 16 2018 9:31pm
Oldandconfused
Front CV joint?
Not a grinding noise; that could just be dry steering bump stops which need greasing. Probably not that lucky
Post #554343 Mon Apr 16 2018 9:54pm
Brit Plumber
Sounds like it may be as my dad calls it, Knock on Lock. Does it sound like a regular knock or a regular snapping noise? If so, sounds like an outer CV joint. I'm not sure how the RRS drive shaft is assembled but on most cars, the CV joint can be replaced if you have the tools. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #554352 Mon Apr 16 2018 10:26pm
Montanafish
It’s like a metal snapping noise I guess.
Post #554356 Mon Apr 16 2018 10:56pm
