Home > Maintenance & Modifications > Gear selector surround removal
I think you are meant to use the loop on the jack handle. (if you can get it in)
See there is a good reason to have one Laughing
https://www.ebay.co.uk/itm/RANGE-ROVER-SPO...SwCHZayKrL
Post #554162 Sat Apr 14 2018 3:52pm
gogsy1956
Dead right Andy,,, thats what I used, but space is a premium, if I were to do it again I would try something flexible. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #554164 Sat Apr 14 2018 4:19pm
Brit Plumber
Do you think, looking at the location of the loop, that it’s possible to attach a lanyard to it permanently (i.e. a red loop of webbing etc.) and place it under the cap in the cup holder? Would the angle of the cable prevent it?
I’m thinking I would like to relocate the loop or attach something to it so that I can release the EPB if (or more likely when) it fails when I’m away from home (and my tools). 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #554199 Sat Apr 14 2018 8:49pm
gogsy1956
You'll probably have to give it a try just to see how far it pulls the loop across. It's not directly under the EPB switch anyway so it may well work,,,, or just keep a small Phillips driver in the boot as you can prise the gaiter off with your fingers 2010 RRS, TDV8
22" overfinch
Post #554200 Sat Apr 14 2018 9:14pm
Oldandconfused
Thanks for that, the plan was to loop a cable tie through the wire loop for a bit of leverage.
Post #554203 Sat Apr 14 2018 9:56pm
