Home > General > Tdv8 oil leak
RRSV8
Tdv8 oil leak
Hi guys
I recently noticed small pool of oil under drivers side just behind front wheel
Had a look underneath undertray back of engine seem to have a wet patch
Went for a drive everything seemed ok no smoke/drove fine
What could it be ? Thanks
Post #553961 Fri Apr 13 2018 2:39am
Is it engine oil (black) or a lighter coloured oil? If engine oil, it could be from the turbo or the PCV pipe. Light coloured oil could be dynamic response system. 2012 SDV6 - it's missing a couple of cylinders
Post #554056 Fri Apr 13 2018 7:04pm
RRSV8
Checked engine bay fluids & dynamic fluid on right side near airbox
was below min, So must be that, is it easy repair ?
Post #554070 Fri Apr 13 2018 8:16pm
Depends where it's leaking. The pipes themselves aren't that easy to do, I believe, as they're well buried. The pump is also well buried and requires the generator (alternator) to be removed first. Probably needs to go on a ramp and a good look to establish exactly where it's leaking first. It's the sort of job that has a big labour cost because the pipes aren't easy to get at. Big Cry 2012 SDV6 - it's missing a couple of cylinders
Post #554087 Fri Apr 13 2018 9:22pm
RRSV8
Hey guys
Just to update, since i last posted, topped up the dynamic fluid to max
which hasnt gone down still on max, engine oil seems spot on
but still have random oil drips on floor, def a light coloured fluid
could it be transmission oil ? no fault codes at all so far.
Post #556222 Fri May 11 2018 8:12pm
