![]() | Home > General > RRS ride quality comparison. |
grey17 Member Since: 18 Jul 2016 Location: Devon Posts: 68 ![]() ![]() ![]() |
RRS 05-09 vs facelift 2010 TDV8.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
I found lowering the (rear) tyre pressures made a massive difference.
Thanks Andy. I'm running mine at 32 psi all 'round at the moment and you're right, lowering the rear pressures help a lot.
wilchesth Member Since: 11 Mar 2018 Location: Falmouth Posts: 41 ![]() ![]() ![]() |
Good tip! I’m on 20” and I also find it a bit stiff and I’ve got 33psi at the front and 36psi at the rear. Will try that tomorrow. Unless anybody here thinks it is a bad idea? 2008 Range Rover Sport 2.7 SE Zermatt Silver. |
I think there are about 4 pressure options on the label inside the door.
I've totally rebuilt the suspension with all new shock absorber and air bag assemblies as well as ride height sensors, ace bars and compressor! Its as near new handling as its ever been after the previous owners neglected it. Is the dynamic mode something that can be switched off? Thanks |
Then very strange that you are experiencing a harsh ride with a new suspension. I can’t point my finger at anything else but then I’m no expert.
I run 255/55/19, no issues here at standard pressures of 36R/33F, but at towing pressures of 42R/38F it is a little harsh so I drop the back down as soon as my heavy load is finished with |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 416 ![]() ![]() ![]() |
"Yours is a 2010 so won’t have the dynamic mode. It came in from MY12 onwards."
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
I have a 2010 tdv6 and it has the dynamic mode with adaptive dampers.
Not “dynamic response” but “dynamic mode” that can be switched on and off using a button next to the terrain response dial? Surprised this was available in pre MY12 cars. Always thought it came in from MY12 |
Yes mine has dynamic response (arc) and dynamic mode . |
I think I might have to go back to 19" rims but shame there are only two styles that fit over the calipers.... At least the spare will then correctly match for size ![]() Thanks G |
