![]() | Home > General > Won't warm up |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
This won’t help much |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
please don't quote me... as I'm not to sure on how the air con is setup on the RRS...
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 ![]() ![]() ![]() |
Yes drove it over an hour
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5121 ![]() ![]() ![]() |
press the ECO button on the climate control (this shuts the AC Off) and then see if the vicious fan is behaving better, and see if you get an improvmeent |
In my opinion if the thermostat was failed open, it would take a long time to get to temp. If it failed closed it would get Very Hot under load and very quick.
Mine is doing the same takes what i think is twice as long to warm up have got a new thermostat to go in |
I pressed eco button and monitored
Good news |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Not to be a smart arse, but the thermostat is closed when cold and opens when hot.
Usually story is, for the cost of the thermostat, you may as well replace it if you have it out. But nice to establish a cause.
speaking from experience the seal being torn/failing does keep the engine from getting warm, and that’s on the 4.2. So a diesel would never warm up. |
I did see some where the other day think it was with those Atlantic people and the seals to go a bit |
The thermostat on the 2.7
