Home > Faults & Fixes > jeep wont start dash lighting up with warning messages
Page 1 of 4 1234>
dulcie
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
hi I think I may have posted this in the wrong place yesterday in technical I wonder if someone could give me some advise or help as my rrs hse tdv6 07 wouldent start and all sorts of warning lights on dash red and green caution when cornering immobilizer hand brake suspension locking and unlocking stereo and sat nav going off after a couple of seconds aa came out and removed a few codes but said comms problem phoned a auto electrician he said body control module aa took jeep to a independent landy garage for a diagnostic had the jeep for a few days and fella who does diagnostic left so I had to pay for recovery to another landy specialist to do a diagnostic two days later I phoned up too buisy with jobs the next afternoon said his mate thinks its a plug under back bumper not done diagnostic next afternoon he phoned with we found your problem its the head unit sent me a whatsapp with a ohmsmeter in the car with the radio going on and off they said they found a head unit in Poland labour charges up to press seven hours I didn't ask you to work on my jeep all I asked for was a diagnostic and I can or will try and replace the parts and get a diagnostic lr2 from carsoft left it after the bank hols and phoned we will charge you a hour and half labour and couldent do a diagnostic as your jeep wont communicate with our diagnostic system paid the bill and had jeep recovered bill said hour labour and so much for diagnostic took head unit out to replace but then thought can you guys help or put the head unit back and send jeep to stratsstones main dealership the last garage said in the whattsapp video and text that one side of radio reading high voltage and other side low both on can link radio going off when it shouldn't all your help and advise greatly appreciated
Post #553232 Thu Apr 05 2018 11:29am
Socast
Not to start on the wrong foot, but it’s a car, suv or Range Rover. A Jeep is something else entirely. Thumbs Up
If the garage are saying that the radio is the problem disconnect it and see if the car drives fine (your satnav will stop working but it won’t effect all the other systems).
Have the battery and alternator tested, it would also be worth seeing if any error codes have been stored.
As it stands though it’s quite difficult to diagnose, these vehicles are full of electronics. It only takes one system to go on the fritz and it can cause a cascade effect, lighting your dashboard up like a Christmas tree in the process.
I think the most important thing with owning one of these vehicles is finding a garage who knows them and whom you can trust Thumbs Up
Post #553236 Thu Apr 05 2018 12:22pm
dulcie
took the radio out and disconnected It did nothing someone told me to do that first as it worked for them dash still lit up like a chrimbo tree she is a range rover sport hse tdv6 auto battery and alternator was checked battery is only a year or so old gonna order a brake pedal switch and a compressor relay and do what I can if I reach a dead end then its off to main dealers or a reputable lr specialist recovery fella told me that he has never brought back a rrsport from them so they must know how to fix them
Post #553240 Thu Apr 05 2018 12:45pm
I think you need to get your computer keyboard fixed as well, as the full stop and comma key don't appear to be working.
Post #553241 Thu Apr 05 2018 12:52pm
dulcie
Good on u, Thanks for your guidance on my typing skills, will try and sort it.
Post #553243 Thu Apr 05 2018 12:59pm
Oldandconfused
I don't think Col was having a dig, we all know how stressful it is when one of these things goes wrong.
what I will say is that this forum is populated by enthusiasts who want to help, but in fairness, when you look at several hundred words without a pause for breath, it does put people off from reading it thoroughly and doesn't help them understand your car's symptoms.
It sounds like the best advice given is to find a good land Rover independent who understands them as you have been given the run around by the garage you took it to. Don't take the word of the AA chap as correct either, I had home start out over the cold spell as mine wouldn't start and he told me my battery was fine. It wasn't so I put a new one in and it's started on the button since and no warning symbols (heated screen now works as well).
If you ask on here, someone may be able to recommend a good indi near you.
Good luck with your car, they are sent to try us.
Post #553246 Thu Apr 05 2018 1:29pm
dulcie
thank you ever so much, just getting used to tode tintanet, will plod on and tick off[ the to do and check list] I have compiled off this forum about similar problems and if no joy will add a new battery on buy list before its carted off to cost me a fortune, hope tode weather is good down your end and keep thy bowels open ode lad.
Post #553248 Thu Apr 05 2018 2:06pm
Obviously I never worded my comment very well or made the point of it, which was, if there was some form of punctuation in the original post it would be far easier to read and understand, rather than one sentence containing several hundred words.
Post #553271 Thu Apr 05 2018 10:16pm
dulcie
You were right col, as oldand from Norfolk pointed out I was in a mess when putting all the faults and garbage I had just gone through. No hard feelings mate it was my fault,I should have been clear composed and precise.things are looking up now I had the chance to get my hands on my baby, armed with all the notes from otherposts similar to mine. Went through all fuses,cleaned every plug to wiring replaced radio and centre console ,hard reset connected battery, no faults coming up on dash but still won't turn over with turn of key,no radio or start up lights,so took battery off,and on chcharge whilst tomorrow, if no improvement then dealer here I come.
Post #553275 Thu Apr 05 2018 10:45pm
Thumbs Up No worries my original comment probably came across sarcastic, rather than constructive I'm sure.
Post #553276 Thu Apr 05 2018 10:52pm
dulcie
You put me on my toes that's for sure and it takes a big man to know himself, lets forget it mate, I think its mad that here I am in the uk speaking to someone in new Zealand about problems with a british jeep, one love Col bless you matey.
Post #553279 Thu Apr 05 2018 11:11pm
Only been in NZ for 18 months, moved here from the U.K and brought my car with me (better the devil you know) Rolling with laughter anyway hope you get yours sorted. Thumbs Up
Post #553280 Thu Apr 05 2018 11:19pm
drdelrrs
Have you tried the hard reset - Disconnect battery?
Post #553329 Fri Apr 06 2018 4:15pm
dulcie
yes I did this about three weeks ago ,had the battery on charge since last night, the battery is a bosh s4 and about a year old. going to do hard reset again before I put the battery back on. Thumbs Up
Post #553332 Fri Apr 06 2018 4:58pm
PC76
Hi Dulcie,
From what i have read over the past few months, three things seem to cause spurious faults.
1) blown brake light bulb
2) faulty brake light switch
3) dead or dying battery
question.. does the ignition come on?
if so do the brake lights all come on when the pedal is pressed?and are all the bulbs the same brightness and constant light output or do they flicker on and off?
Post #553592 Mon Apr 09 2018 12:36am
Page 1 of 4 1234>
