Home > General > I have no fuel - apparently!
kernowkid66
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Hi all, (RRS 3.6 V8 HSE)
On my way to work last night - the fuel low level warning come on and the digi fuel gauge read empty! (put half a tank in 30 minutes previously) The 'miles to empty' gauge also showed up as 3 dashes instead of any figures.
Is there a fuse I could check or something I could reset?
Many thanks,
Post #553184 Wed Apr 04 2018 4:38pm
Tim in Scotland
There were problems with senders in the fuel tanks in some cars so it could be the sender. Which year is the car - from the photo I can see it is after 2010 facelift but which model year? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #553199 Wed Apr 04 2018 8:15pm
kernowkid66
Hi Tim - it's a 2010 model.
Post #553233 Thu Apr 05 2018 11:46am
kernowkid66
Ummm, I have reset the ECU. The fuel gauge worked for a few minutes then went back to empty. Is this a classic sign of a sender fault? I would have thought if it was the sender it would either work or not!
Post #553238 Thu Apr 05 2018 12:38pm
If you look in My Gallery for file No. 37, you will find a PDF file which can be downloaded if you wish, which may help with your problem as it is a known issue.
Post #553272 Thu Apr 05 2018 10:24pm
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Had the same fault about 6 months ago (2011 RRS). Got the same link from Col and forwarded it to our local Indie. Tank was dropped & sender unit connectors changed. Worked correctly since. Think I was charged about £80.
Post #553278 Thu Apr 05 2018 11:11pm
kernowkid66
Thank you Col and fdhadi. Very helpful. I'm of to my local garage this morning to see what he says. I shall go armed with this info.
Once again, many thanks.
Post #553295 Fri Apr 06 2018 8:43am
Russben
I had my fuel tank sender wiring modified by the dealers under extended warranty as it was a known issue.
Mines a 2010 TDV6 3.0 I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #554513 Wed Apr 18 2018 5:50pm
