![]() | Home > General (L494) > Ad Blue question |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
Add blue is cheap and sold at every service station, petrol outlet. Why bother with water when you can fill with the right stuff anywhere anytime? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
As I said, just a question.... |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
your exhaust gas regulation sensors would probably notice leading to a DTC and shut the car of, if it ever would start anyway. I would not advise this, given the sensitivity of the sensors the DPF and catalic converter. You might be confronted with high repair costs RRS 3.0 SDV6 HSE Lux
When I was driving trucks in 2007 I got one of the first trucks (Daf) with it fitted,,the company got 3 new trucks & we used to just top them up with water till the truck companys got wise to it then in 2008 one of the drivers got a new truck put water in it & it detected a problem & went into shut down.
Blimey third top up in 8000 miles |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
The DPF is upstream of the SCR catalyst, so that would be unaffected by water. However, there will be NOx sensors both upstream and downstream of the SCR catalyst, so these would read zero NOx reduction if only water was injected, despite the ECU looking for some difference in the values from the sensors, before and after. I suspect that this would raise a fault and bring on the engine MIL light. I am not sure of the JLR protocol for what comes next, but probably a derating of the engine to limp-home mode. Then the next time a cold start is attempted, it would not start. That is pretty standard across the industry.
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595 ![]() ![]() |
Or a visit to the local pig farm |
bluestone Member Since: 11 Aug 2015 Location: Manchester Posts: 155 ![]() ![]() |
30 months
Dobby Member Since: 02 Jan 2018 Location: East Seaxe Posts: 102 ![]() ![]() |
I didn't even know it had Ad Blue.. do all L494 MYs have it? |
No, not before 2016MY IIRC. My March 2015 build doesn’t have it 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
From Sept 2015 (MY16 cars) 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
or in other words, just the Euro 6 engines.
Springer Member Since: 10 Apr 2009 Location: Peterborough Posts: 20 ![]() ![]() ![]() |
My MY17 had its third top up at the annual service having done 8500 miles. |
