Home > Technical > Nipping steering wheel
Rooney81
Norway 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi all
I have a 2006 Range Rover Sport 2.7td.
Lately when I have been driving on the motorway or at least at speeds of 50mph and higher sometimes I feel a nipp or a yank in the steering wheel, from 1 to 4 or 5 small nips. Very strange. you dont feel it in the car, it does not change direction or anything but it is very uncomfortable when you are cruising along smoothly and then these nips. It is not much, if we think of the steering wheel as a clock it is about 2 or 3 minutes of movement but you feel it very well.
I have studless winter tires and studdet winter tires on seperate set of wheels and it does it on both sets so it is not the wheels/tires. I have new lower arms and tie rod ends and track rods, new lower steering column, new wheel bearings (all the most expensive Advance Factors had to offer) so that should be fine...
I have been thinking what it might be. Drive shafts ? Front diff ? (no other sound from there, grinding or nothing), bad power steering pump, bad serpentine belt....
Any masters out there that know or have an idea what might be wrong ??
Thank you in advance Smile
Post #552640 Thu Mar 29 2018 9:31pm
AnotherMutley
Rack?
My D3 had a similar issue at Motorway speeds and on certain types of roads I'd get what felt like a 2-3 degree of centre shimmy/judder that was more violent than wheel wobble. Changed bushes, checked wheel balance, about to give up hope and then changed the rack and the tugging went.
Post #552893 Sun Apr 01 2018 5:07pm
shepp
Could be the universal joint on the steering rack
My last RRS started out with a clicking, then to intermittent stiffness and finally to slack in the steering. I replaced the below and all was well.
They used to be around £90, but now they appear to be considerably more.
https://www.island-4x4.co.uk/steering-colu...25929.html MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #552908 Sun Apr 01 2018 7:34pm
He's already covered that:
Whistle 2012 SDV6 - it's missing a couple of cylinders
Post #552912 Sun Apr 01 2018 9:38pm
shepp
Oops missed that one. MY12 RRS HSE
Gone 90
Gone s2000
Post #552914 Sun Apr 01 2018 9:45pm
Rooney81
Thanks guys for pitching in.
It has to be the rack, pump or belt I think.
I will monitor it an see if/when it gets worse I will figure something out.
Again thanks Smile
Post #552994 Mon Apr 02 2018 8:28pm
