![]() | Home > General > Alternator volts when charging. |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
It is normal for the alternator to churn out higher voltage after starting and then regulate down after a while.
| Jampot1979 Member Since: 23 Jun 2017 Location: Bedfordshire Posts: 145
The battery is showing 12.6v before starting.
| phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198
Mine shows around 15v with the engine running which I thought was high but a couple of the experts on here said its perfectly normal. |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
15 is quite normal get a volt meter across the terminals your battery might need a good charge depends how long it was on the shelf |
| All times are GMT |
