Home > General > LED interior lighting
Smarttech
After some help with a good LED bulb kit for my L320 RRS.
I purchased a super bright led kit from eBay a year ago and replaced all the interior bulbs and it looked great but 12 months on and they are all starting to fail one by one πŸ™ˆ
Is there anyone that supply a good kit or is it a case of just keep replacing what I have as they fail ? 2019 4.4 SDV8 Autobiography Velocity blue.
2017 SVR. SVO Scafell grey Ebony interior. Gone
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #552578 Thu Mar 29 2018 7:10am
Buckster
This is exactly why i have never done this, because i have never found a quality kit including all the necessary bulbs needed. Hopefully someone will point us in the right direction Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #552584 Thu Mar 29 2018 8:43am
Powerful UK do a set for the whole vehicle:
https://www.powerfuluk.com/vehicles/range-...erior.html
Out of stock currently but the door cards can still be bought. No idea if they're any good as I haven't tried them but they are something I'm considering. Not for looks but for more light, especially in the boot. 2012 SDV6 - it's missing a couple of cylinders
Post #552590 Thu Mar 29 2018 10:45am
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I've just fitted a set of PowerfulUK LED's and they are nice and bright, I'm very happy with the upgrade but mine have only been installed a few weeks so I've no idea on reliability. The light colour is very nice too, it improves the dash in my opinion.
If anyone does go for these then the rear number plate lights are a terrible fit, particularly the right hand one but it does go in. I expected it to break first, but it goes. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #552593 Thu Mar 29 2018 11:04am
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
As I mentioned in a previous post I bought the full set of LED bulbs from PowerfullUK. The lamp fittings for the door puddle lights and under dash lamps were very loose after fitting and the number plate lamps no matter how hard I tried would not fit as the male connector built into the lamp unit was of bad manufacture and simply would not connect to the car loom.
Post #552599 Thu Mar 29 2018 12:42pm
Buckster
So for me reading here, terrible fit and quality dont bode well for these, if they cant get the fit right i wonder how long the LEDs will last. Think i will pass on Powerful UK Whistle 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #552602 Thu Mar 29 2018 1:44pm
Brit Plumber
This is the kit I was looking at
Anyone tried? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #552644 Thu Mar 29 2018 10:18pm
Smarttech
I was thinking this myself. Mine were just bulb replacements so fit perfectly but only seem to last just over 12 months.
I would rather change every year than have badly fitting replacements! 2019 4.4 SDV8 Autobiography Velocity blue.
Post #552652 Fri Mar 30 2018 12:57am
I used these, not cheap but Philips give 12 years lifetime guaranteed for what it's worth, been in 3 years and have not had one fail yet.
Post #552654 Fri Mar 30 2018 1:38am
Cymruambyth
Wales
I bought these. The only ones which were the wrong type were the visor ones which didn`t bother me. 6 months on and still ok.
https://www.ebay.co.uk/itm/RANGE-ROVER-CAN...SwCGVX2rNl Steve.
Post #552676 Fri Mar 30 2018 12:37pm
PDC
I can vouch for Powerful UK. I had a full set of interior LED's from them and two years on not a single problem. I know if you look around you can find way cheaper, but you then hear bad reports about them.....
So I guess it's a case of "You get what you pay for" Thumbs Up 2010 RR 5.0 Autobiography
2020 F-Pace SV
2018 RRS HSE Dynamic 3.0
2015 Disco XXV
2011 Disco 3.0
2008 RRS HST V8
Post #552684 Fri Mar 30 2018 2:19pm
Smarttech
Hopefully these are better than the ones I have as have just taken a punt and ordered a set. 2019 4.4 SDV8 Autobiography Velocity blue.
Post #552709 Fri Mar 30 2018 6:11pm
Cymruambyth
Wales
Thumbs Up Steve.
Post #552745 Fri Mar 30 2018 11:50pm
Meiang
As mentioned previously the door puddle lamps supplied by Powerfull UK fitted very loosly. Today one partially fell out and gouged the plastic trim which runs along the base of the door opening as the door was being closed.
Post #553714 Tue Apr 10 2018 4:45pm
Brit Plumber
I wonder if that’s because they are meant for post face lift door cards rather than the pre. Or vice Versa. 2019 5.0 SC SVA (Current)
Post #553715 Tue Apr 10 2018 5:15pm
