![]() | Home > Technical > Help brembo calipers/alloys |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
As long as they arenβt catching their is nothing to worry about.
| RRSV8 Member Since: 18 Mar 2018 Location: nottingham Posts: 56
Thanks for reply, they are catching slightly so don't want to risk driving etc
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533
I have 22`s with Brembos with no issues. Shouldn`t need spacers. Steve. |
| Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656
Maybe he is using the larger 6 pot Brembos? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
| jzive Member Since: 23 Feb 2014 Location: Essex Posts: 80
6pot brembo upgrade recently done (calipers/disks a L494 take-off) to 2010 TDV8 running standard 20s with no issues whatsoever. with brakes/feel considerably more responsive than standard. |
| PDC Member Since: 13 Dec 2015 Location: Warwickshire Posts: 163
3mm clearance will be enough and as a rule of thumb run with the minimum thickness spacer you can get away with..... |
Just to update tried 5mm spacers, new wheels cleared oem 4 pot brembos perfectly
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
This may not help directly but I had real probs with the 19 inch winter wheels I bought for my TDV8. In the end I had to sell them. Did contemplate spacers but was worried about risk of an issue with my insurers. The offset is a key figure in wheel purchase and it became a minefield for me.
Your next step is to purchase a set of extended wheel nuts and that will solve that particular problem. But as Easter pointed out you have the wrong offset wheel and this will be the only way to correct the problem if you want to keep the rims. 2010 RR 5.0 Autobiography
What is the correct offset & where can I buy extended nuts from ?
Have a look eBay for longer wheel nuts, or better still Advance Factor, they are site sponsors. As far as offset, any rim off a 494 should fit as they all run with 6 pot Brembo callipers. Supercharged RRS 1 also ran with 6 pots. |
spoke to the company who supplied the new wheels, was told if i want these wheels to fit
For the price of a set of wheels nuts I think I would go with that option. Iβm not sure I fancy wheel milling option over a new set of nuts. ππ» 2010 RR 5.0 Autobiography
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9158
Be worth checking what load capacity the wheels have too. Many aftermarket wheels aren't really designed for the weight of a RRS. 2012 SDV6 - it's missing a couple of cylinders
| All times are GMT |
