Home > Technical > Tow Bar Too Long?
alex31283
Tow Bar Too Long?
Hi folks,
I'm a RRS newbie having bought one a few weeks ago. I also bought a second hand tow bar on eBay which doesn't seem to fit the properly. It appears to be too long to then lock into place.
Am I being an absolute muppet or could there be a problem?
Cheers in advance.
Alex
Post #552290 Sun Mar 25 2018 8:16pm
riverblanche
Hi and welcome
may be worth posting a photo, which bit is too long Question Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #552298 Sun Mar 25 2018 10:13pm
Eaters
Re: Tow Bar Too Long?
alex31283 wrote:
Hi folks,
Cheers in advance.
Alex
If it’s the detachable tow bar you’re talking about and specifically the attachment to the RRS then it might be that you just have to be more “assertive “ with it. But as Riverblanche says pics would help. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #552300 Sun Mar 25 2018 11:36pm
alex31283
Cheers for the replies guys.
It is the detachable tow bar. Where the arrow is, seems to be hitting the top of the houseing before the locking mechanism kicks in.
I tried to be assertive to the point of trying to jack the tow bar into position but it just won't fit.
Cheers again for any suggestions.
Post #552308 Mon Mar 26 2018 8:27am
Eaters
Sorry about stating what's probably the obvious, but have you checked the workings of the tow bar without it being fitted. As far as I can remember, if you push the little silver protrusion, then the tow bar locks into place. Obviously you can't fit it if the tow bar is in its locked position so just check that you are not trying to fit it whilst locked. Once again I'm sure you've sussed this but no harm in just checking... Robin
Gone:
MGZTT 190 2.5
Post #552315 Mon Mar 26 2018 10:30am
alex31283
Hi Eaters,
Does the small pin completely retract? It seems to go half way in but not completely. I had wondered if this was normal?
Post #552318 Mon Mar 26 2018 11:08am
Eaters
I'll go and check mine. Photos may follow but the pin doesn't disappear altogether even when locked. Robin
Gone:
MGZTT 190 2.5
Post #552321 Mon Mar 26 2018 11:26am
Eaters
So Picture 1 shows the tow bar ready to be fitted - note that the main locking bar is fully retracted
Pic 2 is the tow bar locked
Pic 3 is a close up of the pin with the tow bar locked
Hope this helps Robin
Gone:
MGZTT 190 2.5
Post #552322 Mon Mar 26 2018 11:37am
alex31283
Cheers Eaters. I'll take a look when I get back home.
Post #552329 Mon Mar 26 2018 12:28pm
Godders
Mend with a disco 4 was having the same problem and he wasn't actually pulling out the spring loaded green sleeve where the key is. He had just turned the key and it won't go in unless you also pull the green bit so that you can see the red collar. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #552349 Mon Mar 26 2018 5:49pm
Eaters
Good point Godders.
So the action on the green knob is pull out then twist Alex Robin
Gone:
MGZTT 190 2.5
Post #552350 Mon Mar 26 2018 5:53pm
alex31283
Thanks for the assistance guys but I've tried and its like the large silver protrusion can't reach the hole on the receiver to go through and then lock into place. Could it be the receiver that's damaged?
Post #552356 Mon Mar 26 2018 7:01pm
Godders
That was exactly what was happening with my friends tow bar until he pulled the green bit away from the body Can you push the small silver pin in with your finger when it is unlocked ? Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #552358 Mon Mar 26 2018 7:20pm
Buckster
The receiver can rust inside and get full of all sorts of grime and dirt so would be best to clean that out first, then give it a spray of WD40 and have another go Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #552359 Mon Mar 26 2018 7:23pm
alex31283
Gooders, the small pin pushes in slightly but not a huge amount.
Buckster, I'll get the wire brush and WD40 out tomorrow and give it a go.
Cheers folks
Post #552361 Mon Mar 26 2018 7:35pm
