![]() | Home > General > Wont, start, dash warnings, faults etc... Help |
| Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298
Hi pal same as my tdv8 this morning
| Jampot1979 Member Since: 23 Jun 2017 Location: Bedfordshire Posts: 145
I just managed to get it started after disconnecting the battery for an hour. But the dash was telling me so many errors. Turned it off, went to restart and it's dead again. |
Same here MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
I was wondering if when I washed it that water has got on something.
Well... I think I fixed it. Noticed the negative battery connection was loose even when the clamp nut was done up tight. So I played around with it and got it tight on the battery.
Thanks Pal, i will try that
Let me know how you get on |
will do MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Any luck? |
Hi Pal no luck, so had it on a low loader and had it dropped to my local Indy, as soon as i hear anything i will update
Sorry to hear that... Hope it's a simple cheap fix.
Glad to hear it, hope yours stays well |
| Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567
Good luck Mani, hope you get it sorted easily (and cheaply!) 2016 RRS SVR Estoril Blue
Thanks, Scrumpy MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
| All times are GMT |
